Source JeepForum
FAQ: Will it rub? By (NaeKid) http://www.jeepforum.com/forum/f96/faq-will-rub-610856/
The JK with stock wheels, no wheel spacer, no lift
32" tires: no rubbing
33" tires: minimal rubbing unless extended bumpstops used
35" tires: don't try unless extended bumpstops used
The JK with stock wheels, 1 1/4" wheel spacer, no lift
33" tires: some rubbing on full turn which can be controlled by extended bumpstops
The JK with stock wheels, 1 1/2" wheel spacer, no lift, Bushwhacker flat-top flares
33" tires: no rubbing
35" tires: rubbing that can be cured with trimming pinch-seam
37" tires: don't try
The JK with stock wheels, 1 1/4" wheel spacer, 2" lift
35" tires: some rubbing
The JK with stock wheels, no wheel spacer, 2 1/2" lift
34" tires: some rubbing on street, sway bars connected
35" tires: significant rubbing
The JK with stock wheels, 1 1/4" wheel spacer, 4" lift
35" tires: no rubbing
37" tires: some rubbing - trim flares and pinch-seam
38" tires: be careful
39" tires: don't try
